engine oil in radiator, NO water in oil
Old Aug 1, 2014 | 04:23 PM
drrusscampbell's Avatar
I have a 98 Mustang there is black oil in the radiator, but NO water in the oil. Any ideas
Old Aug 1, 2014 | 04:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: engine oil in radiator, NO water in oil
Hi drrusscampbell ,
You'll likely get better response at a Mustang board , since this board covers 82-92 Camaro and Firebird only . As a generic answer , not knowing anything about Mustangs , have you done a pressure test on the cooling system ? And if it has an automatic transmission , have you checked it's fluid ?
Good luck
Old Aug 1, 2014 | 07:11 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Mustang
That's a dirty word round here !
Old Aug 1, 2014 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Fluids go from high pressure to low pressure. Cooling system maxes out around 15 psi. Oil can be up to 80. Without knowing anything about a mustang since this is a third gen site, the only thing that comes to mind is an engine oil cooler. I have no idea if a mustang uses an oil cooler or not.
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
