no start
Old Aug 8, 2014 | 08:39 PM
ainfante's Avatar
no start
I have a 86 iroc 350 tpi having trouble with no spark. I already changed the control module , coil , and the electronic spark control cheeked all the fuses is there a relay that controls the ignition? Need help thanks
Old Aug 9, 2014 | 07:11 AM
BHicks's Avatar
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
Re: no start
How bout the coil?
Old Aug 9, 2014 | 02:32 PM
ainfante's Avatar
Re: no start
I replaced the coil on the distributor cap and still nothing thinking it might be the pick up coil
Old Aug 9, 2014 | 03:39 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: no start
does it spin over? have you checked for spark at the plugs? did you buy your parts from auto zone? ( if so, that may well be your problem). you may have a problem with your distributor. I have the exact same car, AND a factory service manual, so I probably can help you.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
