AC/Smog/Tensioner Bracket Removed
Old Aug 13, 2014 | 01:21 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Thought I would post up some pictures on what I did for a belt tensioner. I wanted to remove the stock serpentine bracket because the only thing that was going to used was the tensioner.
Attached Thumbnails AC/Smog/Tensioner Bracket Removed-img_20140806_094736_104.jpg   AC/Smog/Tensioner Bracket Removed-img_20140806_094702_393.jpg   AC/Smog/Tensioner Bracket Removed-img_20140806_094647_713.jpg
Old Sep 8, 2014 | 11:37 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: AC/Smog/Tensioner Bracket Removed
What kind of tensioner is that?
Old Sep 8, 2014 | 11:40 AM
Car: 88 GTA, 74 T/A
comp cams for a LS motor.
http://www.jegs.com/i/COMP+Cams/249/54021/10002/-1
Old Sep 9, 2014 | 06:18 AM
3rdgenmaro's Avatar
Car: 88 IROC
Thanks. Looks pretty good. A little expensive for what I plan to do with the car, so I may just end up being ugly with a ac delete pulley and no smog pump.
Old Dec 24, 2018 | 03:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am interested in this conversion. What serpentine belt are you using with your set up?
Old Dec 24, 2018 | 08:31 PM
NoEmissions84TA's Avatar
I like how the bracket and spacers work to contain your wires and hoses.
But it is hard to tell from the picture and even Jegs description - is it actually a spring-loaded tensioner?
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
