question
Old Sep 11, 2014 | 09:45 PM
kenjames23's Avatar
Car: 1982 Z28
Engine: 350 880 block
question
this is what i have i have a vortec 350 with 193 heads but i pulled those and i am going to go with my 1989 Corvette Aluminum Cylinder Heads, GM 14101128 my question is do i still have to use self aligning roller rockers
Old Sep 12, 2014 | 04:49 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: question
Hard to for me to give you a for sure answer without seeing them, but all aluminum headed engines I've seen either had guide plates or self aligning rockers. If the push rod slots are small so the push rods barely have any 'wiggle' clearance then you want NON self aligning (but I've never seen aluminums like this). If you have guide plates then you want hardened push rods and NON self aligning. If the slots are wide open and no guide plates then use self aligning rockers. Make sense?
Old Sep 13, 2014 | 10:15 PM
kenjames23's Avatar
Car: 1982 Z28
Re: question
ok thank you
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
