What springs with Crane 2032?
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
The recommended springs are part no. 98602. They cost $160, and that's ONLY for the springs. I called Summit and the guy reccomended this kit. I'm just looking for a drop in replacement, without having to play with shims or spring pockets.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: What springs with Crane 2032?
That should work.
What brand is the 98602? I cant find info
Edit, you mean crane 96802? Similar seat pressure at higher height but they have higher spring rate i like on hydraulic rollers. That cam is mild enough it should be ok with what you have in the summit kit
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I'm dropping a 2032 into my LO3 this winter and looking at this kit as well. Have you completed the install?
Car: 1988 Camaro
Do you need seals, locks and retainers too like that kit has? Or do you just need the springs?
Either one of these will work, both $30. I have used Howards springs for 10 years. In fact have used these 2 on many diff engines over that 10 year span.
Here's the correct links
http://www.competitionproducts.com/H.../#.VFchRPnF9QE
http://www.competitionproducts.com/H.../#.VFchcPnF9QE
Here's the common umbrella seals $3 http://www.competitionproducts.com/V.../#.VFchsvnF9QE
PC type seals $16 http://www.competitionproducts.com/P.../#.VFch6fnF9QE
Engine: 5.7, 5.0
Both links take you to default page. In my case, I definitely need new seals, however, will take a look for these to compare specs.
Car: 1988 Camaro
Ok I edited post with links that work
Engine: 5.7, 5.0
Ended up just getting these the other week from a seller on here, new in box along with seals for a good price.
http://www.summitracing.com/parts/cca-981-16/overview/
Single, 1.254 in. Outside Diameter, 370 lbs./in. Rate, 1.150 in. Coil Bind Height
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engine-drivetrain-suspension-parts/714753-new-comp-springs-locks.html#post5882426
LT1Formula
Oct 8, 2015 08:34 PM
