Strange Tocking Sound From Exhaust
Old Oct 3, 2014 | 10:30 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
Hey guys ive got a 85 Trans Am with a recently swapped vortec 350 with, Stealth ram, cc503 cam, 1.6 roller rockers, and around 10:1 compression.
I used the exact same headers and exhaust on my 305 with no tock/knock. The exhaust isnt hitting anywhere that I can tell. I did have to do some major massaging to the y-pipe to get it to clear the oil pan on the vortec( its still extremely close to the pan). Could it possibly have something to do with the tune? Its a bit on the rich side but I dont think that would cause the noise. It also seems that the muffler really magnifys the noise. If i remove the muffler the tock/knock is much harder to hear. If anybody has any idea what it might possibly be let me know!
Heres a link to the video. Its kind of hard to hear the tocking in the video, Its most audible near the end.
Old Oct 4, 2014 | 12:02 AM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Re: Strange Tocking Sound From Exhaust
1. Beautiful color of blue you have.
2. Why are your exhaust resting against the bottom of the rear bumper cover?
3. When doing exhaust work , I feel to make sure there is clearance for at least my fingers to pass between the exaust and the car's body and frame to allow to movement without rattling against anything.
Old Oct 4, 2014 | 09:09 AM
mlbinseattle's Avatar
Car: '84 Camaro Z28
Engine: 305 HO
I agree with MintWS6FORMULA. In the video, those pipes appear to touch the rear bumper cover. I didn't hear any "tock/knock" as you described. Sounded pretty normal to me.
Old Oct 4, 2014 | 12:15 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
Thank you I personally think its one of the best color combos for TA's. The exhaust is up against the bump cover because I like the look of it. Its actually just barely touching. Its been like that for 3 years now with no discoloration of the bumper or any other negative side effects.
Heres some pictures of the clearance. I only have space between the pipe and the pan to fit a piece of wire. I don't have any other clearance issues.
Attached Thumbnails Strange Tocking Sound From Exhaust-photo-1.jpg   Strange Tocking Sound From Exhaust-photo-2.jpg
Old Oct 4, 2014 | 12:19 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
The noise is definitely harder to hear in the video. It could be described as a sort of popping noise. I never noticed it until my brother pointed it out to me and now its all I hear.
Old Oct 4, 2014 | 12:26 PM
Joe Tag's Avatar
Try slipping in a piece of rubber or cardboard to isolate it for a test. That's probably not enough clearance. You can also go under there and thump the exhaust around and see if that's your noise.
Old Oct 4, 2014 | 01:40 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
[QUOTE=Joe Tag;5826205]Try slipping in a piece of rubber or cardboard to isolate it for a test. That's probably not enough clearance. You can also go under there and thump the exhaust around and see if that's your noise.[/QUOTE
Just tried that, it didn't make any difference. I wonder if all the hammering ive done has caused some restrictions that are producing the noise? it seems plausible.
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCtometal
Sep 2, 2015 02:01 PM
