Air diverter valve ?.
Old Oct 10, 2014 | 10:51 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
On the air diverter valve, there is 2 solenoids. Is there a place where you can just buy the solenoids or do you have to get the whole diverter valve? The black solenoid is bad on mine and since they are removable, I would think they would be available separate. The gray one tests good. I got the intake off my car and I figured I would test the diverter valve and the egr solenoids to see if they are still working. I don't want to buy the whole diverter valve new since they range from 250 to 500. I just need the one solenoid. I guess my best bet would be a junk yard but I thought I would ask first.
Old Oct 14, 2014 | 09:54 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Air diverter valve ?.
Can you read the part number off of the solenoid? I would imagine that it is available and that it was probably used on various applications, maybe for other purposes. You might be able to cross the part through someone like NAPA. The issue with NAPA or any other retail parts store is getting past the limited capability of the counter person to the companies actual parts listings, which are in fact vast. You will probably not find that part by application. Only by crossing the part number. Most parts stores will have the parts suppliers' catalogs which list a vast array of vacuum solenoids and will have a cross reference chart.
Standard Motor Products
Delphi
Remy(maybe)
AC Delco
These are a few of the aftermarket parts suppliers that may list that part.
1992 Trans Am
May 10, 2023 07:19 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
jackhammer
Aug 15, 2015 10:04 PM
