Cranks but wont start
Car: 1989 GTA
Engine: 383
My car has been hard starting lately and will not start now. I verified 40psi at the fuel rail and checked the distributor cap. I noticed a flaky rusty residue around the pickup coil. I have no idea how old most of this car is so while I had it apart for the pickup coil I replaced that, cap, rotor, icm, and the ignition coil.
It still wont start so I connected a plug directly to the ignition coil and it does not spark during cranking. Scanner isnt reporting any codes.
Any ideas why I cant even get it to spark?
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Cranks but wont start
First verify you are actually getting that 40psi. 2nd is your replacement ICM from autozone? If so verify you are getting correct voltage to it as I got a replacement from autozone and it was bad out the box, returned it for a 2nd icm and it has been working for 4+ years.
EDIT: also I've heard that if your oil sending unit goes bad it will not allow any spark to the icm.
Car: 1989 GTA
Engine: 383
Beyond measuring the pressure with a gauge Im not sure how I can verify it? It smells like gas under the hood after I crank so I'm guessing it's flooding.
Yes, that scares me because the icm is from the Zone. To test the icm am I looking for some voltage output to the tan/blk wire to the ecm?
