Need help setting timing on a 305
Old Oct 17, 2014 | 12:20 AM
oxygen454's Avatar
Car: 1988 Firebird
Engine: 5.0L
I'm setting the timing on a 1988 firebird 5.0L 305 fi.
I have adjusted timing on other cars and trucks but this engine is a bit different. Maybe you guys can fill in the blanks..
Get engine up to operating temperature
Shut engine off
Mark scribed line on harmonic balancer pulley with white out or paint pen to show line better
Disconnect something ??
Loosen distributor timing bolt
Attach timing light to battery and plug wire #1 (drivers side front)
Start engine
Adjust to 8 or 0 (on the before side)
Tighten bolt
Grab a beer
So mainly I need to know the bolt size ... 9/16?
And do I have to unplug a wire connector before setting the timing? I see two wire harnesses connecting to the bottom of the distributor.
Old Oct 17, 2014 | 01:48 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Need help setting timing on a 305
Ya,,,okay...gran me a cold one.
Loacte the EST bypass connector...single wire connector (on my 89 IROC, over by the pass side wheel well)
Okay...disconnect that plug, start the car, shoot the light at the HB and mark
TPI spec is 6 BTDC...no idea about TBI..
So once timing to spec. shut the car off, plug in the Bypass connector, tighten down the hold down,,,go for a ride.
Old Oct 19, 2014 | 10:29 PM
oxygen454's Avatar
Car: 1988 Firebird
Engine: 5.0L
So timing is somewhat set lol. I could hardly see the timing numbers and set it to 4 btdc. So i will reset to 6 tomorrow. The engine is a TPI. I had to disconnect the brown wire and used a crows foot wrench which was 9/16. Now the engine runs way better, it was past 0 atdc.
My friend messed with the idle screw so I had to throttle up the engine a tad to see the timing line. It idles around 500 rpm.
I might set the idle up to 800rpm?
Old Nov 1, 2014 | 06:05 PM
Ferro's Avatar
Car: 91 RS
Engine: 5.0 TBI LO3
Transmission: Built 700R4
Axle/Gears: LSD
Whats going on fellas. I'll sum it up. 91 305 TBI. I pulled the distributor in order to drop the tranny for a quick rear main seal replacement. While I was there I replaced the oil pan gasket so I had to turn the engine. Note; distributor out, however I did mark it. I put it all back together and attempted to start it up but will only crank with a-lot of back fire and spit ups with the occasional flame from the tbi. What's next???
Old Nov 1, 2014 | 07:48 PM
Lift the dist until it clears the cam gear; rotate the shaft EXACTLY 180°; drop it back in; try again.
Old Nov 1, 2014 | 09:30 PM
oxygen454's Avatar
Car: 1988 Firebird
Engine: 5.0L
I would also set the engine to tdc on cylinder #1 and check to make sure that the rotor is pointing to number one plug wire on the cap.
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
