Smog pump noisy
Old Nov 7, 2014 | 08:57 PM
botch1's Avatar
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
Smog pump noisy
I have a 87 350 TPI Iroc Z. The smog pump is noisy any sounds like is rattles. I can actually here it through the firewall when engine is running. Is it shot? or can repair it? I suppose I cannot take the belt off to disable smog pump. Any help would be great. THANKS JIM
Old Nov 8, 2014 | 05:41 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Smog pump noisy
It's likely shot. The A.I.R. pump has some flimsy vanes inside that can rattle. I replaced a noisy one with a rebuilt Cardone unit and it's been good.
There is a way to remove the pump and re-route the belt, but I'm not sure how.
Old Nov 8, 2014 | 07:54 PM
Damon's Avatar
Re: Smog pump noisy
Yeah, it's likely just worn out inside. They get noisy, then they fail.
Fortunately on an 87 it's a separate belt that turns just the smog pump off the water pump pulley. You can remove the belt and/or remove the whole air injection system, if you want (only needed for emissions). The computer does not monitor it's functioning at all.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
