Idling problems
Old Nov 10, 2014 | 09:35 AM
dibella989's Avatar
Car: 1988 Trans Am GTA
Transmission: 5-Speed
Axle/Gears: 3:45
Idling problems
1988 305 TPI, so sometimes it will start up flawlessly, but other times it'll die if I don't sit there and give it gas for 2-3 minutes, and even after waiting I'll be idling at 500 rpm. My idle ranges from that 500 to 1300ish, solely depending on startup. This is when it is both warm and cold out.
Old Nov 10, 2014 | 10:06 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Idling problems
Do a search on here for "TPS and IAC Setting procedures. Sounds like it could use it.
Also check for codes.
Here.......It's your luck day. I done it FOR you. Open the link up and follow it to a "T"
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
It should help.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
