Tech help
Old Nov 27, 2014 | 09:15 AM
Noel_z28's Avatar
Car: 1988 camaro
Engine: 5.0 305
Tech help
So after so long i finally got my l69 305 engine rebuilt (5-speed),
Now i need help wiring it up and knowing what sensors i will need,
And what wiring i will be able to delete, so far these are the after market parts i have bolted down;
Lunati 256-262 cam
Lunati timing set
Edelbrock non egr Performer RPM Intake Manifold
Edelbrock 600 carb
Edelbrock fuel pump
Edelbrock waterpump
Melling m-55hv oil pump
Hedman headers
And yes i will be runnnig A/C and power steering i just need a walk thru
Old Nov 27, 2014 | 09:17 AM
Noel_z28's Avatar
Car: 1988 camaro
Engine: 5.0 305
Re: Tech help
This is my car that the motor will go back into
Old Nov 28, 2014 | 11:36 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Tech help
You don't need a whole lot of wiring.
Alt
Starter
water temp sender
Oil pressure sender
Tach signal wire
HEI 12 volt switched
Elec. choke 12 volt switched wire
Heater/AC
Windshield wiper motor
windshield washer pump
Horn "
Front lights (headlights, blinkers, parking lights)
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
