Fuel Pump Issue
Old Jan 12, 2015 | 08:15 PM
garagepro's Avatar
Car: '86 Iroc
Transmission: 5-speed
Fuel Pump Issue
When I turn the key forward, the fuel pump primes and then shuts off. Car may start momentarily but then dies. The fuel pump is not pumping. If I apply 12 volts direct to fuel pump the pump runs just fine.
I replaced the fuel pump relay and still have the same problem. Any Thoughts?
Old Jan 12, 2015 | 08:20 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Fuel Pump Issue
The pump is supposed to prime for 2 then shut off when you kick the key 4ward.
Now when you start the car and it dies, maybe the ECM isn't getting a crank signal from the ign module or the oil psi switch is bad?
Old Jan 12, 2015 | 09:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Pump Issue
You didn't Tate where you applied the power to the pump, at the relay to eliminate c100 ? At the oil pressure switch ? Have you checked the fender well fuse ?
Old Jan 12, 2015 | 09:56 PM
Engine: Lb9
Transmission: M20
Re: Fuel Pump Issue
Old Jan 13, 2015 | 11:19 AM
garagepro's Avatar
Car: '86 Iroc
Re: Fuel Pump Issue
Thanks guys - this will really help me troubleshoot. Fender fuse is good. Applied power to pump at relay. I'll try replacing the oil pressure switch in a few days when it warms back up here.
Old Jan 13, 2015 | 12:23 PM
Engine: Lb9
Transmission: M20
Re: Fuel Pump Issue
To bypass the ops for testing make a jumper wire and connect to the orange and grey wire. The ops will be above the oil filter or back next to the distributor.
Old Jan 20, 2015 | 09:43 PM
fatherson91's Avatar
Car: 1970 K25, 1986 K5
Engine: Both 350s
Transmission: SM465
Axle/Gears: Dana 44/60 10-bolts
Re: Fuel Pump Issue
Did you get it fixed? I have a similar problem, but engine never fires. I hear the fuel pump relay kick on then off. Going to bypass the relay too, to test it.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
