1.6 roller rockers
Old Jan 19, 2015 | 11:59 AM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
1.6 roller rockers
I have a GMP crate motor 330 hp. It has 1.55 rockers on it now. If or can I put 1.6 rockers on the engine and change the profile of the cam? Would it make it run any different?
Old Jan 19, 2015 | 06:00 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 1.6 roller rockers
What cam is in it? It's likely to be the ZZ3/ZZ4 cam in a 330 GM crate motor. If so, you won't gain anything from 1.6's on the exhaust, but may pick up just a smidge on the intakes.
Old Jan 21, 2015 | 04:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Its a carry over cam from the mid-late 90s 300 HP 350 crate engine. I think it is like 212/222 @ .050 with .435/.460" lift. With stock heads he is going to run into valve seal to retainer clearance issues on the exhaust side. He should be able to get away running 1.6s on the intake and 1.5s on the exhaust. The Ramjet 350 uses the same cylinder head/valve springs with a full set of 1.6 rockers on a cam that has .431/.451" lift. Exhaust lift on the Ramjet 350 is .481" which is at the absolute limit of a stock vortec head.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
