fly wheel/torque converter making ticking sounds.
Old Jan 19, 2015 | 04:13 PM
78elki's Avatar
Just this past weekend I deleted my air injection system mostly because of all the exaust leaks it had..now im hearing a tick or knock from around the flywheel area. I replaced a lot of the vaccume lines that were bad including the shift module on my 1978 305 CID engine. Is there other vaccume lines I missed? Also I bought a new edlebrock air cleaner what do I do with the vac lines coming from the trans moduelator and the one from behind at the bottom of carb can I plug any especially the 2 nipple one on the intake manifold.
Old Jan 19, 2015 | 11:54 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: fly wheel/torque converter making ticking sounds.
A loose torque converter bolt will do it.
I bought one a while back cheap due to this. Man was selling it as "runs but engine knocks" I looked at it and it sure enough knocked but only in drive or R, not in park.
I bought it, got time to mess with it, got under the car and checked the converter bolts, 2 was loose. Tightened them and the knock in gear went away.
Also a cracked flexplate will do it.
Exhaust leak at the rear or bottom will too
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
