Help with oil cooler delete
Old Feb 18, 2015 | 08:37 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Ok guys i got some questions. If i take off the lines going to the oil cooler and leave unplugged will coolant or oil come out? What is the hex size bolts i have to replace so i can take off the oil cooler adapter to be able to screw on my oil filter? Thanks
Old Feb 19, 2015 | 11:38 AM
robg91z's Avatar
Engine: 350ci TPI
Re: Help with oil cooler delete
Anyone? Need my car up and running again by today
Old Feb 19, 2015 | 11:47 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just wondering, why r you taking the cooler off?
Old Feb 19, 2015 | 12:43 PM
robg91z's Avatar
Engine: 350ci TPI
Heater core is busted and leaking inside and did a carb swap. No need for heater either way.
Old Feb 20, 2015 | 02:09 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Pretty sure you can delete heater without removing oil cooler
Old Feb 20, 2015 | 07:30 PM
TTOP350's Avatar
Yup.
Old Feb 21, 2015 | 01:29 AM
92Formula94's Avatar
If you only want to delete your heater core, you can cleanly run the heater core hoses together, there are adapter fitting, or just get one hose for a cleaner look and go on deleting your heater components
Hotrodboba400
Dec 10, 2019 07:07 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
apie2546
Sep 5, 2015 07:40 PM
mantaguy
Sep 2, 2015 10:42 PM
