Skip White 65k Distributor/cap
Old Mar 4, 2015 | 06:59 PM
jahblah's Avatar
Car: 87' Firebird Formula
Will the Skip White 65k HEI distributor/cap fit or will it hit the firewall? It has the larger, round, flat coil top and it looks bigger than the regular HEI cap.
Old Mar 4, 2015 | 07:48 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Skip White 65k Distributor/cap
You're going to be real mad at yourself if you buy and install that POS. Skip sells OK stuff collectively but that's definitely not one of them.
Old Mar 7, 2015 | 08:35 PM
Damon's Avatar
It will clear the firewall. Earlier 3rd gens used large cap HEIs, so the firewall was designed to clear them.
Skip White stuff is a bit hit-or-miss. Sometimes they work great, sometimes not. They crank out a lot of them so they rely on a good warranty/return policy to fix any problems, not so much on up-front QC.
Old Mar 8, 2015 | 03:28 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
from what others here have posted, I wouldn't buy from skip white. period
Old Mar 10, 2015 | 11:16 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I like Davis Unified Ignition aka D.U.I.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
89bird2.8
Sep 25, 2015 09:21 AM
KCG
Sep 23, 2015 09:05 AM
