HYPER EUTECTIC PISTONS RECOMMENDATION
Car: Z-28
Engine: 355
Axle/Gears: Stock
Hi to all,
I have a roller Gen 1 350 .030 SB. with Cast Crank and Rods. I am using Trickflow twisted wedge heads, GM ZZ3 Roller cam 208/221, lb 112.
Looking for some 350+ HP out of this engine. I am looking to replace my pistons with some Hypereutectic ones.
There are several brands on the market. But KB and Speedpro seem to stand out.
I will not be running any NOS nor Boost not the engine.
Looking forwards to some comments.
thanks!
thanks!
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: HYPER EUTECTIC PISTONS RECOMMENDATION
Hi to all,
thanks!
thanks!
Car: Z-28
Engine: 355
Axle/Gears: Stock
HI, thanks for your comment. i have done some web research and the opinion on the KB is either love or hate... which I don't see with SpeedPro... I want something reliable. any more thoughts?
Car: 86 IROC
Engine: 5.0 TPI
well, KB has a rep that cant be beat. on the other hand, speed pro is very good too. I have used both and always have gotten good results from both.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I have speed pro's in basically the same motor and I'm pushing 330hp on my motor. No issues in over 6 years.
Car: 86 IROC
Engine: 5.0 TPI
and there you have your answer, I prefer KB because of their being closer at "0" deck than speed pro. however, speed pro cant be counted out either. basically, you need not consider any others but these two choices.
Car: 1984 Trans Am
I went with speed pro because they were cheaper. Also, my shop didn't deck the block. Make sure you Zero deck your block. It was a stupid oversight on my part.
Car: 86 IROC
Engine: 5.0 TPI
correct blue printing of the block is a "end all , be all " kinda thing. if your piston is down in the hole any at TDC you give away compression. the idea is to have the top of the piston flush with the block at TDC. I cannot overstate the importance of balancing and blueprinting. these two things are the difference between a well running engine and a grenade
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
I'm not a fan of speed pros. I rebuilt my 383 last spring and the keepers were being pushed out of the piston. Had too tap all the wrist pins out with a hammer. Soft metal from a made in India piston.
Car: 1984 Trans Am
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Our 388 motor had Keith Black pistons in it and we raced using those pistons for 8 years.
Car: 86 IROC
Engine: 5.0 TPI
it is sometimes hard to find a honest ,knowledgeable engine builder. those of us who care to build for longevity. always ask the owner a bazillion questions before the first bolt gets turned
Engine: 4++,350 & 305 CIs
Some very late 92 TPI motors got the LT1 hypereutectic pistons, they are lighter but don't spark knock them much or you'll have a oil pan full of pistons..
LT1s and the LS motors run them with great success (for a stock piston)
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
I've run both and would run either one again - even sprayed 150 shot on a set of speed pro's after running it in a circle track engine for almost 3 seasons turning 65-6700 rpm. Ran a set of KB's in a 377 turning 7800 for 2 seasons with no problems too.
If you go speed pro there are 2 pistons = the H345's which have a 1.548 pin height and a H273 that has a 1.605 pin height
Car: Z-28
Engine: 355
Axle/Gears: Stock
Thanks to all for the replies.. I have never imagined there is that much involve in pistons... I am looking for a reliable engine.. My engine block had some flat badger B557 pistons and I just basically want to replace them with some hyper eutectic pistons. I need a part number that matches those badger B557 pistons. Any thoughs?
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
