1991 rs problems
Old Mar 8, 2015 | 08:15 PM
Rmurphy70590's Avatar
1991 rs problems
Heyy I'm having a problem with a 91 rs I just bought. It's a 5.0 5speed car. It's not getting fuel and the gauges go crazy when I turn the ignition on. I've replaced the fuel pump, relay and checked the fuse. Could it possibly be the ECM??
Old Mar 8, 2015 | 08:37 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 1991 rs problems
Since about the only thing that the gauges and ECM have in common is the battery , NO , your Gauges going crazy have nothing to do with your ECM . When you say "it's not getting fuel" are we to think you can hear the pump running for the 2 second prime at key on , with no pressure at the rail ? Or , are you hearing no pump action at all ? Yes , the ECM does control the pump for the 2 second prime and could be at fault if the pump relay and all other pump circuits are functioning normally and it's NOT doing the 2 second prime . Have you checked all the ground wires for both the dashboard and the ECM ? Sometimes when people hack aftermarket radios into these things all kinds of wiring gremlins appear because of wires being cut by these inept installations .
And yea , the ECM and the dash also have the ignition switch in common , but it's not a normal failure mode of the ignition switch to make the gauges go crazy . This is almost always bad grounds or hack wiring shorting wires that really would rather not be shorted ....
Best of luck with it , and welcome to TGO
Old Mar 8, 2015 | 08:56 PM
Sry I forgot to say that no I'm not hearing the pump at all. My next step is to take the pump back out and check the wiring in the tank. I just wanted opinions on the ECM thing before I fight with all the wiring. The stereo was hacked up so it's a good possibility it's that. I can also hear the injectors workin so I know it's not them. Thank you for ur response
jhawkeye
May 25, 2022 06:33 PM
bjpotter
Jan 22, 2019 12:27 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
