remaned vortec heads
Old Mar 9, 2015 | 12:29 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
is this a pair of vortec heads from rock auto?
remaned vortec, $342.79
in the description it lists 16 valves, but seems cheap to me. If it is a set is there any reason not to do these over rebuilding my 416's? by the time I do enlarged valves plus the parts to rebuild I would think this might be a better option.
Old Mar 9, 2015 | 07:36 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: remaned vortec heads
You would have to run a vortex style intake.
Old Mar 9, 2015 | 07:55 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
That is for a single head and it's about the going rate for a stock reman head. When it says 16 valves that means the engine is 16valve - unlike the newer overhead valve engine where you've got 32 valve v8's and such - it's another data point to identify the engine - makes more sense when you see it as options such as a 2 liter 8 valve or a 2 liter 16 valve...
That said I wouldn't go with those heads since the springs will likely need to be upgraded to run any sort of decent cam or the guides cut for high lift, etc. I'd find a set and have the local machine shop rebuild it and cut the guides for high lift cam clearance.
Old Mar 14, 2015 | 12:22 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
you are FAR better off having a competent machine shop go through your "416s" . you DO realize they are a 305 head??
Old Mar 15, 2015 | 07:10 AM
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
I would look at Summit Racing® Cast Iron Cylinder Heads for Small Chevy SUM-152123 There a cheep head but would be way better than a stock head and would probably be cheaper than getting a new intake, self align rockers, springs, maybe retainers and possibly machine work done on top of getting a set of vortec heads.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
