What Header gasket for Edelbrock T.E.S
Old Mar 12, 2015 | 12:32 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm getting the header ceramic coated so I'm going to need gaskets. Copper ones for sure. Trying to figure out if I go round or square port? The header is round and the head is square. Edelbrock calls for a 1.5" X 1.5" square regular material type gasket. I just can't find that exact measurement in copper. There's 1.5 x 1.46, I assume that's close enough. Thought?
Old Mar 12, 2015 | 04:21 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: What Header gasket for Edelbrock T.E.S
Here goes a similar discussion.
https://www.thirdgen.org/forums/exha...kets-what.html
Old Mar 14, 2015 | 10:46 AM
Bigfoottpi11's Avatar
Just use regular Felpro or something like that, but whatever you do make sure you Elongate the holes , trace it with a marker and make sure it matches the heads, cause you can blow out header gaskets pretty easily. Plus it will flow better if you elongate the gasket openings.
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
