HELP Please (Opinions)
Old Mar 15, 2015 | 01:40 AM
Rakim_RS25TH's Avatar
My camaro won't start!
im having the some problems in my automatic 92 rs 25th anniversary . it has a 350 . the battery guage doesnt work but one day it started up but turned off two seconds later & would crank but not turn on. Then i turn the key no dash light heat or radio no power to widows tried to start it but it wouldnt crank anymore i tried jumpstarting it & it wouldn't crank but not turn on. Until i removed the cable trying to get opinion.....thanks ahead of time
Old Mar 15, 2015 | 01:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: HELP Please (Opinions)
With no interior power, check the wires down by the starter. One of them has a fuseable link that provides interior and other car power. It's possible that this shorted out and needs to be replaced.
It's also possible that those wires simply came loose or your solenoid itself went bad and isn't allowing power through.
If all that is good and it cranks and cranks, I'd suspect the ignition module in the distributor.
Old Jul 5, 2015 | 10:48 PM
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
