Trans cooler and radiator swap
Old Mar 20, 2015 | 04:14 PM
FattyL's Avatar
If I'm going to swap my stock radiator for one of the universal aluminum ones, how much or how big of a trans cooler do I need to install to equal whats already there? (Stock 700-4 Trans. 95% race track 5% tooling around on the road)
Old Mar 20, 2015 | 06:30 PM
Damon's Avatar
Re: Trans cooler and radiator swap
You want something BETTER than what's on there if you do 90% race. If you're talking drag race (especially if you do some hot-lapping sometimes), overkill is just about right. Drag racing throws a LOT of heat in a trans very quickly.
I've even seen guys use the old A/C condenser as their trans cooler. Personally, I doubt that an A/C condenser would be nearly as efficient as a cooler built specifically for transmission cooling, I'm just saying I've seen it done and they never had trans overheat problems.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
jharrison5
Aug 19, 2015 05:53 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mizz0313
Aug 12, 2015 06:45 AM
