Trouble code headache
Old Mar 26, 2015 | 06:55 PM
visceris's Avatar
Car: 1991 Pontiac Firebird Formula
Engine: 305 5.0 TBI
I keep getting code 23. I have reset the computer memory and it keeps coming back. I cannot find a definitive answer anywhere as to what it is so i was wondering if you guys had any ideas. Thanks all
Old Mar 26, 2015 | 07:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Trouble code headache
Check your Manifold Air Temp Sensor (MAT) That will give you the code 23.Resetting doesn't fix it.
Old Mar 26, 2015 | 08:07 PM
visceris's Avatar
Engine: 305 5.0 TBI
Ok which one is that exactly? Is that the one that hangs off the cowling over the AC system or is that somewhere on the intake?
Old Mar 26, 2015 | 08:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
I never had any experience with a MAT Sensor, here's a diagram,it says it's the the Air Cleaner.
Old Apr 11, 2015 | 11:26 PM
visceris's Avatar
Engine: 305 5.0 TBI
ok i changed out that sensor but the code is still there..even reset the memory again just to be sure...code 23 again...grrrr
Old Apr 12, 2015 | 12:29 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
http://www.chevythunder.com/mat_code_23.htm
This should help. Start troubleshooting. Replacing parts blindly usually just costs you money.
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Dec 5, 2015 09:22 AM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
