A/C Belt Vibration (Did Anyone Solve This?)
Old Mar 29, 2015 | 08:49 AM
RED85TPI's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 bolt Borg Warner Posi 3.27
I've read many people complain on this site about their A/C V-Belts vibrating at idle when the A/C compressor turns on.
No one has resolved the issue and just give responses like "the compressor is bad" "the clutch is bad". Not taking into account that most of the time, people notice the issue after replacing everything.
I have recently replaced ALL of my A/C components and noticed the belt vibrates when idling.
I followed the replacing procedure meticulously after doing hours of research.
The belt has lots of tension, all the bolts are in, and the bracket is connected to the heads....
does anyone have any REAL experience with this problem and corrected it?
I appreciate your help!
Old Mar 29, 2015 | 01:55 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Re: A/C Belt Vibration (Did Anyone Solve This?)
I have a similar problem with my alternator belt. Sometimes when I start the car it's squeaks to high hell. Have no idea how to fix it. I have already tried to tighten the belt.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
