92 1LE Z28 not starting
Old Apr 1, 2015 | 07:40 PM
rodu's Avatar
Hello all. I am new to the forums because I need you help. I parked the Z28 7 months ago and it was running fine. I installed a new battery before storage and then had a trickle charge on it the whole time. Car cranks over great but I get no spark at plugs. I had the ICM checked and it is fine. I get over 1400 ohms from the pick up coil. I have changed the coil and even the ECM but still nothing. I have checked the distributor cap and rotor they appear in good shape. All wiring is in great shape.
Fuel pump puts out over 40 psi. All fuses have been checked.
It started once when I had no. 1 plug out and grounded to see if I had any spark. I replaced the plug and then there was nothing. I tried the same thing but no luck. I am at a loss. Any ideas good people?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
