No fuel pressure after fpr..
Old Apr 10, 2015 | 06:33 PM
Jackrabbit501's Avatar
Car: 1986 Camaro
Engine: 355 tpi
Hey guys, small problem here, im getting fuel pressure before my fuel pressure regulator, but not after it. What would be the problem?
I replaced the fuel pump a while back.
Also my fuel pump no longer kicks on in the key on position. I swapped to a 350 hsr with a new harness and computer. Could the computer be the problem here?
Old Apr 10, 2015 | 07:21 PM
Re: No fuel pressure after fpr..
Most FPRs are designed that way... they have pressure on one side, and dump excess fuel into the return line (0 psi) to regulate.
So, probably no problem at all.
Old Apr 10, 2015 | 07:50 PM
Car: 1986 Camaro
Engine: 355 tpi
sofa,
so would that mean i have my fuel lines backwards? lol
I tried following what information was with holleys kit, but i was also wondering about the pressure in the return. i have my fpr before injectors..
I disconnected the fuel rail and left the crossover disconnected, ran the fuel pump, but it wouldnt push through the regulator
Old Apr 12, 2015 | 08:27 AM
Right; the pump doesn't "push through" the regulator.
Pressure line should hook to one fuel rail; the crossover should go from the other end of that one, to the other; the regulator should be in the far side of the 2nd rail; return line should hook to the regulator.
Old Apr 12, 2015 | 09:29 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
On this same question. I also had my FPR changed and now I am not getting accurate reading on my FP gage. Is the Schrader Valve need to be in that port or not???
Old Apr 12, 2015 | 10:25 AM
Schrader valve should go anywhere in the pressure line or fuel rails, before the regulator.
Changing the regulator shouldn't have affected the gauge accuracy. Maybe the regulator isn't regulating right?
Old Apr 12, 2015 | 11:20 AM
DJP87Z28's Avatar
Thanks...so there is a Schrader valve in that port.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
