1991 RS v6 stalling problems
Old Apr 15, 2015 | 01:09 PM
ProtocolXero's Avatar
Car: 1991 Camaro RS
Engine: V6 3.1 MFI
Transmission: Automatic
I've had my car for almost an entire year and I have yet to manage to find a fix for the stalling. For a period of about 2 months there was a point where it didn't stall. It's stalling again and now the idle is extremely low in neutral and when I come to a stop in drive. I've replaced the ignition switch, spark plugs and wire set for them, new distributor cap, new IAC valve (twice), new EGR valve, and new fuel injectors. None of these fixed the stalling issues. I'm at my wits end for this thing. Someone please send help!
Old Apr 15, 2015 | 06:04 PM
ex-x-fire's Avatar
Re: 1991 RS v6 stalling problems
Make sure the egr isn't getting vacuum at idle (which it shouldn't).
Old Apr 18, 2015 | 07:48 AM
Car: 1991 Camaro RS
Engine: V6 3.1 MFI
How would I go about doing this?
Old Apr 18, 2015 | 08:32 AM
ex-x-fire's Avatar
I guess 91s have an electric egr valve, so that's not likely your problem.
I'd start by removing the throttle body & cleaning it good. I think they have a gasket set for those.
Old Apr 18, 2015 | 01:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I noticed that the injectors have been replaced, hopefully they aren't re-mans of the OEM Multecs. If so they could still be an issue.
Since this is a 3.1l with an auto there is an idle learn that needs to be done whenever the ECM loses battery power. Good link to that procedure:
https://www.thirdgen.org/forums/v6/1...dle-learn.html
Note that in that link is also information on cleaning the TB. This too is important as the varnish and carbon build up on the blade causes idle issues.
RBob.
Old Apr 18, 2015 | 02:01 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Also take off the idle air control (IAC) valve and clean all the passages in there too. Check for vacuum leaks and pull the vac line from the fuel pressure regulator and smell for gas. And more detail on those injectors.
Old Apr 25, 2015 | 07:44 PM
Car: 1991 Camaro RS
Engine: V6 3.1 MFI
OK so the injectors are not oem. They are a different brand and definitely better. I've cleaned the entire throttle body and replaced all the gaskets with a direct fit throttle body gasket set I ordered. Idle relearn performed too. Still stalling and a very low idle while coming to a stop in drive and neutral. No vacuum or air leaks either.
Old Apr 25, 2015 | 09:35 PM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
Double check this. Mine was stalling and the exhaust smelled like fuel. I had gas in this line (there should not be any). I replaced the fuel pressure regulator, and now she runs smooth as silk.
Good Luck
Old Apr 26, 2015 | 07:33 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
The EGR Valves in those year models were prone to sticking open due to carbon getting on the pentel seat. It would usually cause a low or rough idle after the engine was warmed up and it would usually set a code, causing the light to come on. I'd pull the EGR valve and clean the pentel and seat to see if that clears the problem up.
Old May 7, 2015 | 09:41 PM
Car: 1991 Camaro RS
Engine: V6 3.1 MFI
The EGR used on this car is different from V8 engines. It's an electric EGR and it has been replaced with a brand new one which did get rid of the EGR SEL code. But it didnt fix the idle.
Old May 8, 2015 | 07:55 AM
poketad's Avatar
Car: 89 Iroc Z
Did you check the ICM?
FormulasOnly
Jul 23, 2018 08:47 AM
Jlanz55
Sep 29, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
amcnellis
Sep 16, 2015 04:16 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
