Moroso Oil Control Kit (Scraper, Tray and Baffle)?
Old Apr 17, 2015 | 09:15 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Has anyone tried running this kit before?
http://www.jegs.com/i/Moroso/710/23035/10002/-1
Looks like an inexpensive option to have a decent oil control setup. The only thing that concerns me is the way the crankshaft scraper mounts between the block and pan. Even only slightly offset on one side, sounds like it could impose possible clearance issues with the pickup screen being uneven with the bottom of the pan as well as open up the potential for pan gasket leaks. If I used the thick blue felpro gasket, would it compress down and conform enough on that one side to even matter?
FWIW, the motor we're talking about is a 3.75" stroke 305 (Yes you read that correctly) with ARP main studs and windage tray stand-offs.
NORTz89
May 20, 2020 03:51 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
