Fuel Injector problems.
Old Apr 26, 2015 | 08:15 AM
sheachopper's Avatar
Car: 1988 trans am gta
Axle/Gears: 4.10
I have a 1988 pontiac firebird gta. I had 2 bad fuel injectors that needed to be replaced. I went to oryllies and got 2 new ones, when I got home, I noticed that the injectors are 2 different lenghts but they guarunteed that they would work. So I installed them and checked for leaks and plugged all my connections back in. now when I go start my car... it will only run for about 2 secons at a crappy low idle. But if I give it gas, the rpms will go up and then die again when I let my foot off the gas. I was going to check for leaks but now my car wont stay started. Anyone know what could be happeneing? possiable air leak? it back fires as well. And If I disconnect my MAF it will stay started but at a verry low idle. Thank you.
Old Apr 27, 2015 | 03:12 PM
southbay08's Avatar
Re: Fuel Injector problems.
I assume that they are 2 different types of injectors. Do you have any leakage from the rail side?
Which injectors do you have? Do have part numbers?
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
