1.6 RR and exhuast note
Old Apr 26, 2015 | 08:42 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
will putting 1.6 RR on a mostly stock l-98 change the exhaust sound like a mild cam would. I was considering going this route because I don't feel comfortable doing a cam swap and not sure if I want to spend the money for a shop to do it
Old Apr 26, 2015 | 10:31 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: 1.6 RR and exhuast note
I am not too sure on the noise it actually makes out of the exhaust but I have heard these things are noisy! Saw a camaro with these rockers in his engine and they make a lot of noise in the engine bay and outside the car regardless of how much you adjust them. A cam swap will make the idle lumpy depending on the cam if that's what you want.
Old Apr 27, 2015 | 12:14 AM
Night rider327's Avatar
Car: 1988 Camaro
No not really. The rocker ratio only adds a couple of degrees of duration @.050", non added to adv. duration and increase the valve lift. This will not really change the exhaust tone or note.
Old Apr 29, 2015 | 07:29 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great thanks
UltRoadWarrior9
Apr 28, 2020 10:39 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Jorlain
Oct 8, 2015 01:57 AM
gord327
Oct 3, 2015 01:25 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
