fuel issues
Old May 1, 2015 | 04:06 PM
ryanp's Avatar
fuel issues
hello all, having issues with a 91' 350 z28. car has been sitting awhile and now wont start. I notice now I cant here the fuel pump prime. Checked fuel pump relay,fuse block by the battery. Doesn't help much but I can get to run with starter fluid. I did notice that the security light on the display does not go out,could there be an issue with the vats system?
Old May 2, 2015 | 12:02 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: fuel issues
I don't know too much about vats, got lucky by having a bird without it. Although I think if it has a security issue it doesn't start at all, and you said you're able to start it with starting fluid
Might be a failed fuel pump. Check the voltage on it with the key on. If voltage seems good I'd check fuel pressure, but usually the mechanical pumps are cheap and easy enough to simply replace..
Did you flush the tank of bad gas and contaminants? Filter may be blocked up too
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
