strange valvetrain noise?
Old May 30, 2015 | 03:12 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
while the microphone doesn't pick it up as well as i'd hoped, the noise starts at 3 seconds and ends at 13 in the above video. after several years of no noise i've noticed a weird clatter/rattle noise that only happens between 700-900rpm when the engine is warm. for instance i hear it quite clearly when the car is in drive and i'm waiting at a light or rolling into a parking lot. as you can see in the video, it does not make any weird noise at idle, it doesn't make the noise at higher rpm.. i'm a bit stumped. rockers all appear fine, set them when I installed them a few years ago and haven't had to do anything to them since. if anyone has any ideas on what that could be or what I should do to diagnose it further, i'd appreciate it.
to clarify, this video was taken with the car warmed up and i had the valve cover off because i was worried one of the rocker bolts may have loosened up or something. all are set properly, though i'm tempted to go through them all again.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Zell1luk
Sep 29, 2015 10:36 AM
