TPS voltage
Old Jun 1, 2015 | 01:07 PM
88blueiroc's Avatar
TPS voltage
Does anyone know what TPIS recommends for TPS voltage? I know that the correct stock setting is .054, Thanks.
Old Jun 1, 2015 | 01:23 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: TPS voltage
.054
Straight from TPIS
TECH TIP: CRISP THROTTLE
Most TPI and LT1 cars have crisper throttle response when the TPS
voltage at idle is in the .60-.65 volt range. Raising the TPS voltage into
this range can also cure a Code 33 problem on 1985-1989 TPI cars.
Old Jun 7, 2015 | 07:27 PM
88blueiroc's Avatar
Re: TPS voltage
I will give it a try, thank you.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
