need bearing advice
Old Jun 2, 2015 | 04:05 PM
MTpockets's Avatar
Car: 1983 Z28
Engine: LU5
need bearing advice
I am using my old crank in a new(er) block I got. I know stock journals are 2.45 main 2.10 rods.
My journals are
mains 2.435 - 2.440
Rods are 2.092-2.094
Can I use standard size on rods and .010 on mains ?
This engine will never be raced, only cruising around to local shows with my son.
Old Jun 2, 2015 | 04:09 PM
MTpockets's Avatar
Car: 1983 Z28
Engine: LU5
Re: need bearing advice
Will these work ?
http://m.summitracing.com/parts/sum-172010
Old Jun 2, 2015 | 04:39 PM
Assuming your measurements are all accurate, your main journals right now are .010" - .015" undersized, and your rod journals are between .006"and .008" undersized.
That's pretty messed up.
I'd suggest getting your crank turned to some standardized size, and then buying bearings that fit whatever it ends up at.
Old Jun 4, 2015 | 08:29 AM
MTpockets's Avatar
Car: 1983 Z28
Engine: LU5
I have spent the last couple days angry that this crank is holding up my by build again. I was out in shop when I noticed this (see pic) . If it was ground .010 there is no way I was getting some of those measurements.
Then the lightbulb came on ! The micrometer I used was that dandy piece of shat from HF. Grrr... A quick trip to friends house to borrow his more accurate Mic. Journals are now 2.089 and 2.439/2.440.
So engine guru's ,,, if I run .010 bearings will that get me back in the game ?
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
