Keep getting trouble code 33
Old Dec 18, 2001 | 03:22 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
My engine light came on and I noticed a big power loss. So I connected the pins with a paper clip and got trouble code 33 which is low vacuum at the maf sensor. Anyone know what causes this and how to fix it?
Old Dec 18, 2001 | 11:09 PM
TBIfly's Avatar
code 33-as i understand it, you can check the vacuum hoses from the sensor. Check the electrical connections at the ECM under the dash. ultimately just replace the sensor. i have no idea what causes it to go bad though
Old Dec 19, 2001 | 01:12 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check the vacuum hoses and all the connectors, and check your TPS settings!
/N.
Old Dec 19, 2001 | 02:23 AM
Guest
Guest
Posts: n/a
The last thing I'd be doing is replacing the sensor. Try checking the wiring (fans sometimes eat the wires), check the pins on the connector and MAF, and try replacing the MAF relays.
I assume this is a TPI car, right?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
