New Fuel Tank Cap - Suddenly have Code 44?
Old Jun 14, 2015 | 10:10 PM
KNIGHTE's Avatar
Car: 1985 TA http://bit.ly/1EadkbO
Engine: 5.0 V8 LG4 BBL
Transmission: 5 Speed Manual
LG4 Engine,
Put on a new Fuel Tank Cap - The old one was "Ok" but this one was way tighter and seemed to fit better, it was a GM original part.
Next drive i get code 44, i had just washed the engine, and i actually did powerwash around the carb, it was filthy.
So is it the cap, or the power washing, that did it?
Old Jun 14, 2015 | 10:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: New Fuel Tank Cap - Suddenly have Code 44?
Did this show up before or after getting your smog inspection issues sorted out?
Old Jun 14, 2015 | 11:41 PM
KNIGHTE's Avatar
It was after
Old Jun 15, 2015 | 06:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Originally Posted by KNIGHTE
It was after
I ask because they test both the fuel cap and the fuel vapor return system (or whatever it's called). A vacuum leak in this system light cause a lean condition and your Code 44.
Since both were tested and passed, I would look elsewhere. Take the air cleaner off and see if you might have dislodged a vacuum hose when you pressure washed the engine.
Old Jun 15, 2015 | 10:03 PM
KNIGHTE's Avatar
Weird - didn't come up on tonight's drive home....
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
