406 750cfm edelbrock 2000-3000 hesitation
Old Jun 17, 2015 | 02:59 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
Hello everybody looking for a little help I have had my 406 into the car now for a week "85 z28" and I'm really pleased with it except for one problem I have a hesitation from 2000-3000 under load more noticeable in 3rd gear under load less in second gear it's a 700r4 a 750 cfm edelbrock shorty headers and a custom 3 inch I fabbed up myself. I have changed the cap, rotor, plugs, and wires thinking about trying the ign module and switching back to the 600 cfm eddy off my 305 any suggestions would be great.
Old Jun 17, 2015 | 03:01 PM
Regal105's Avatar
Engine: 454, 5.3
Re: 406 750cfm edelbrock 2000-3000 hesitation
Old Jun 17, 2015 | 03:14 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Is that first pic the Y pipe?
My friends 350 had a similar design and an odd stumble when we got on it. Spent days working on carb tuning and ignition and in the end when we put a proper Y pipe and merger on it the stumble disappeared.
Old Jun 17, 2015 | 03:17 PM
Regal105's Avatar
Engine: 454, 5.3
That's interesting if that's the case, the stock y was much the same tho it was like 2 inch into 2.5
Old Jun 17, 2015 | 03:19 PM
midias's Avatar
There are other causes, I would try adjusting the accelerator pump and get a spring tuning kit but
Not saying it is 100% the same but when from this
To this it was amazing and 100% unexpected.
Old Jun 17, 2015 | 03:30 PM
Regal105's Avatar
Engine: 454, 5.3
I was thinking the accelerator pump actually... It is set up for the largest squirt... Gigidy. Which may be to much for this setup
Old Jun 17, 2015 | 03:36 PM
midias's Avatar
Try changing it around and use a vac gauge to check the springs.
Old Jun 17, 2015 | 04:52 PM
Regal105's Avatar
Engine: 454, 5.3
Moved the accelerator pump to the middle position hesitation all but gone now gonna move it down one more step and try it.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
