Requesting Part terminology
Old Jun 19, 2015 | 03:23 PM
Grim89FL's Avatar
Car: 89 firebird GTA
Engine: 5.7
Apologies if people see this as board cancer but i've spent an hour searching google for the names to no luck.
What is number 1 and 2 called?
note: this is not my pic, merely borrowing. Also, if someone does have a site that covers all the terminology for components With pictures, i'll bookmark it for future reference.
Thank you
Old Jun 19, 2015 | 03:34 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Requesting Part terminology
1. k member
2. Center link.
Old Jun 20, 2015 | 01:10 AM
Night rider327's Avatar
Car: 1988 Camaro
Yep... #1 is the K-member or also known as engine crossmember
#2 is the steering center link, also known as a drag link.
The arm that goes from center link to steering gear box is the pitman arm
The longer rods thats on each side of the center link are the tie rods... Closest to center link is inner tie rod end and closest to wheel is outer tie rod end
The arm that bolts to the frame of car and goes to the center link is the idler arm
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
