2.8 won't stay running.
Old Jul 5, 2015 | 01:21 PM
Mr.J.'s Avatar
Just bought an 87 camaro, 2.8 multi port injection. Been sitting since 1995, New fuel pump and fuel pressure regulator. Wants to start but acts like it immediately runs out of gas. Fuel pressure is about 42 psi and stays steady during engine cranking. Misplaced my code reader so I'm not sure of any engine codes at the moment. Any one have any ideas?
Old Jul 5, 2015 | 01:53 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 2.8 won't stay running.
My idea would be that you have 6 injectors glued shut by the varnish that the old gasoline has turned into inside of them . It's starting for a second and dying is likely because the cold start injector (7th injector) has larger openings and isn't clogged like the 6 standard injectors are . To troubleshoot this , get a Noid light on each bank of injectors and make sure they have their spray signal when cranking . If yes , and your sure of the 42 PSI on the rail , it's highly likely they are clogged ....
Old Jul 5, 2015 | 02:33 PM
Mr.J.'s Avatar
Thanks, I was afraid of clogged injectors but that was my next Thought. Any tip for getting those cleaned up other than buying new? I was thinking maybe soaking the tips in acetone in a shallow pan, avoiding submerging the entire injectors.
Old Jul 5, 2015 | 05:33 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hey Mr. J ,
In actual practice I have not seen an easy do it yourself method of cleaning injectors that have been left to sit with fuel in them till gummed up . As your aware (from replacing the regulator) there is some taking apart of upper manifolds such that it's not a quick 10 minute job to take out and reinstall the injectors . Now , once you do take them out you'll need new O rings on them so they will not leak when reinstalled . Were this mine to do , and I'd only want to do the remove and replace ONCE , I'd pick up a set of remanufactured injectors from the site sponsor here known as "SouthBay Fuel Injectors" . This company has sold literally hundreds of injectors here and everyone gives high marks for their product/service . I'm fairly sure that a set of 6 will run somewhere just over $100 , money well spent as even unclogged our factory injectors (Multec) are not as good as the Bosch replacements from SouthBay . I have no connection to this company other than being one of many happy customers of theirs . Now , if your really squeezed for funds , and are looking for the low buck attempt , you do know that each injector has a tiny filter built into the top of it (the end that sticks into the fuel rail) , yes ? Well if you were to get some O rings , take it apart and take those little filters out and clean them , it just may run at least enough to let you know your going in the right direction . A paperclip bent into a hook is all you need to fish the filter out of the recess it sits in and with luck maybe its those little mesh screens plugged up and not the injector pintle itself ......
Old Jul 5, 2015 | 08:02 PM
ex-x-fire's Avatar
Get a long 1/4 dowel or screwdriver, have some one crank it while you listen to the injectors w/ the dowel/driver. Should have a sharp click to them if they are good.
Old Jul 6, 2015 | 08:01 AM
Mr.J.'s Avatar
I pulled the injectors out, the pintles were stuck closed but with some carb/choke cleaner I got then freed up, stuck everything back together and it started right up, smooth idle but I think the idle air control is out of adjustment. New o rings cost me about $20 and a few hrs work, I can live with that. Thanks for your guys' input
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Fronzizzle
Sep 8, 2015 12:10 PM
