Port my trickflow 175's???
Old Jul 8, 2015 | 01:37 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys I'm kinda at a crossroad and would like some input, currently I've got the trickflow 175 heads with 1.94/1.5 valves on my 355 and am wondering if it would worth it to have them fully ported or go with another bigger set, like 195's?? If I go with new I'll most likely get bare castings and go from there but what would you guys recommend? Thanks for your time guys and have fun!!
Old Jul 8, 2015 | 02:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Port my trickflow 175's???
Going to depend on that casting and how much material is left to port. There may be some room to do mild work and clean up and ability to cut for a 2.00-2.02 or so valve. Wont know til someone looks at it. Figure a good port job plus valve work and components is gonna cost 600-1000$. All depends on the person doing the work. So it may make more sense to just sell and buy new.
Also depends on how much power you want to make and how high rpm you want to turn
Old Jul 8, 2015 | 04:11 PM
thatsupnow's Avatar
Hey thanks for the input! Yeah I was thinking it probably be a better idea to just sell the heads I've got and go with new ones. I'm kind of leaning towards the Dart Pro 1 200cc heads I'll be spinning to about 6300 rpm, and I'll be putting in a new cam and 1.6 rollers too. Going with either comp cam xr294hr or 292xfi
Old Jul 8, 2015 | 06:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Those cams with a 200cc head will likely want to go to 7000 lol. Those are pretty big cams
Old Jul 9, 2015 | 12:40 AM
Night rider327's Avatar
Car: 1988 Camaro
I run Brodix IK 200cc heads on a 355 with a solid flat tappet 249/252@.050" .570"/.579" lift, 106 LSA cam and Make peak power at 7200 rpm
I think you would be better off selling the 175's and buying 190-200cc heads.
Brodix, Dart, pro-filers and of course AFR are all real good
Old Jul 12, 2015 | 06:08 PM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
Im getting my TF 175's bowl work and 5 angle valve job in the next week. I basically have a similar setup to you except I have a Superram. I expect to get into the high 11's with my new setup. What is your goal that you are trying to reach and what e/t's does it do with the current setup?
Old Aug 4, 2015 | 11:58 PM
D_Smith87's Avatar
Car: 1987 Camaro Iroc Z28
Engine: comp xr288 /budget aluminums
Transmission: TH350
Axle/Gears: 9-bolt BW 3.42 w/posi
Some afr 195s are a good choice for cams in that range
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
FueledSoul
Sep 30, 2015 09:18 PM
bplessy
Sep 30, 2015 12:14 PM
