Can't properly shim starter.
Old Jul 17, 2015 | 07:58 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
I put on a new starter yesterday. Tried it with no shims and it made a terrible grinding noise. Put one shim on and it still made the noise, but a little less gruesome. Added a second shim and the car started, but still had a nasty noise. Do I add a third shim? The old starter had no shims at all.
Old Jul 18, 2015 | 06:14 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Re: Can't properly shim starter.
Are you sure the nasty sound is coming from the starter? Usually the starter retracts back into it's casing after it's done it's job. Maybe it's getting stuck on the flex plate and casing the nasty sound. What size shims have you used so far?
Old Jul 18, 2015 | 02:02 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
Sorry, should have been clearer. With two shims the starter only makes the noise while its working. Once the engine has started the noise goes away.
Old Jul 19, 2015 | 02:08 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
I'd add another shim.
Old Jul 19, 2015 | 03:21 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I had the exact same issue. I tried up to 3 full shims, started trying half shims, used a feeler gauge to measure clearance - nothing worked. Eventually, I got the car on a left and had someone start it while I was underneath; the starter wasn't going back in quick enough, so the car would start and then the gear from the starter would hit on the flex plate and make a horrible noise. I exchanged the starter (not fun with the custom headers & exhaust) and didn't need any shims on the new one.
Old Jul 19, 2015 | 03:40 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i've been playing with small block Chevies for almost 25 years, and i've never needed to shim a starter... i have, however, bent a few mounting bolts that caused the starter to not mesh with the ring gear properly...
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
dusterbd
Sep 29, 2015 08:40 AM
wstephan96
Sep 25, 2015 04:28 PM
