Vacuum advance for big cams
Old Jul 20, 2015 | 10:03 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
The stock vac advance on my distributor was hitting max advance at about 13"hg and I generally pull about 11". I wanted a rock solid advance at idle so after some searching I found AIRTEX is re manufacturing the B28 advances from the old corvette FI motors. It starts 3-5" and finishes about 8" the PN is AIRTEX 4V1053 and has B28 written on it. My Test showed full advance at 7".
So just a heads up for anyone with a bigger cam.
Old Jul 20, 2015 | 01:12 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Vacuum advance for big cams
i have a Crane adjustable vacuum can on my car... it uses an included allen wrench to adjust the vacuum level that it starts at, and a bolt on limiter with different steps to control how much..
Old Jul 20, 2015 | 03:32 PM
midias's Avatar
Yea I saw that but did not want to spend $40 when i could get exactly what I needed for $10
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
