Vortec head swap. Best combo?
Car: 1983 TA WS6
Engine: 357 (5.7L)
So ive come across some Vortec heads for cheap and im interested to get them. What Casting #'s should I be looking for, intake, springs for my combo? What else do I need? Should I get them machined?
Would my Hooker super comp headers fit?
How much HP gain over double hump heads?
My combo is:
-357
-10 to 1 compression
-Comp cams Xtreme energy cam 12-262-4
-Edelbrock performer Rpm air gap intake
-650 Holley vacuum secondary
-1.5 rockers
-2500 stall Hughes torque converter
-Hooker Super Comp Headers 3 in.
-Hooker Y-pipe 3-2.5 in.
-Custom 2.5 exhaust, small cat, y-pipe to 2, 10" glasspacks rear.
My combo is:
-357
-1.5 rockers
Car: 89 Firebird
Engine: 355 TBI
Re: Vortec head swap. Best combo?
You will be borderline on lift with your cam and stock springs but I think you will be ok. I ran 465 lift cam on stock vortecs for years with no problems. I would get them checked out at a good machine shop if they are used. You will have a pretty peppy engine with this combo and yes probably 20+ HP over the camelhumps unless they've had lots of work done to them
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i just swapped a set of unmolested 906 castings off a 97 Tahoe onto my Camaro a few weeks ago. i checked the retainer to seal clearance with a caliper, and the tightest one was in the .540 range- which means that any cam smaller than that much lift wouldn't have problems..
if you have a roller cam block, then the HOT cam kit from GM (part # 12480002) is the cam you want. runs like a stocker off idle, then pulls like a beast from 3500-7000. you might find cams that make better peak power, but none will probably come close to the overall powerband of this cam- because it was engineered by GM Powertrain engineers for installation in the LT4 Corvettes in 96, but they couldn't get emissions numbers where they needed to be so they put a smaller cam in them..
for the intake, i run an Edelbrock Performer Vortec (2116) because it's the only one that mounts a quadrajet, but if you are a Holley guy for some reason then an Edelbrock RPM air gap (7516) is probably the way to go..
Car: 1983 TA WS6
Engine: 357 (5.7L)
I have an rpm airgap so I would probably stick with it and get another.
Right now im running around 6 seconds to 60. With very little traction.
Car: 1988 Camaro
Vortec heads last 3 digits of casting # 062 or 906.
They will pick up 30-40 HP easy over the double hump heads.
Stock springs are trash.. Replace them with these http://www.competitionproducts.com/H.../#.Va3RuKRViko
Your valve lift does not require machining of the heads. At .464/.470" lift you are a touch under the guide/seal to retainer clearance limits.
Yes your headers will swap over and work just fine on the vortec heads.
You will need a vortec style intake of course.
Also you will need 5/16" dia intake bolts rather than the 3/8" dia ones like you use now.
Use fel pro MS9800T intake gasket set
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
