rattling sound under intake.
Old Aug 7, 2015 | 10:04 PM
mustangman65_79's Avatar
Car: 1989 Iroc
So this is driving me nuts. I'm a frigging car mechanic, and I can't find my own problem.
This normally happens on card starts. SO maybe EGR?
Here is the problem. When I start up the car, Sometimes something under the upper intake rattles. It comes and goes, lasting between 30s and a couple minutes. It normally does it on cold starts, but I have also had it do it while warm.
It sounds like a bad PCV, but it isn't. Is there something else under the intake that runs on vacuum, or another pvc?
Old Aug 7, 2015 | 11:25 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: rattling sound under intake.
Nothing under the plenum(upper intake) should rattle. Maybe you're hearing noisy injectors? Maybe try a mechanics stethoscope and try to isolate exactly where it's coming from.
Old Aug 7, 2015 | 11:27 PM
Car: 1989 Iroc
that's what I thought. But it's definitely under the intake, and nothing inside the motor.
Old Aug 8, 2015 | 11:56 AM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Well if its the oil splash gaurd u will have to remove the intake to check. I read the TPI manifold splash guards were bolted/screws in. The carb intakes had a press fit rivit looking fastener. But if your bolts/screws are loose that tin oil splash guard would rattle pretty good.
Old Aug 8, 2015 | 12:07 PM
Car: 1989 Iroc
Ah, never knew they had this. SO maybe it is inside the motor.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
wanext
Oct 6, 2015 12:18 AM
skinny z
Oct 5, 2015 06:23 PM
Fanatic1074
Oct 2, 2015 03:47 PM
