Non-thirdgen hard start question
Old Dec 19, 2001 | 11:42 AM
formula14's Avatar
Ive got A 94 s-10 blazer with the 4.3. When i try to start it just cranks and cranks but it doesn't seem to catch. when it does catch it starts right up. I changed my coolant temp sensor at the front of the engine. could the fact that my gauge does not work be one of the problems and Is that sensor on my driver side of the block? Is this a starter problem or a senor problem? Thanks guys.
Old Dec 19, 2001 | 10:31 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i believe all GM vehicles also have an oil pressure switch that prevents the engine from starting until oil pressure rises..
you might want to check into that
Old Jan 18, 2002 | 11:29 AM
formula14's Avatar
I have some new developments. When it is really cold outside ,like 20 degrees and lower, it starts up instantaneously. But when it is any warmer it takes forever to get started. I think it is adding too much fuel on startup. How can i get it to lean it out a little. I hope that narrows the possibilites down.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
