Making 300 hp from a 305
Old Sep 19, 2015 | 06:58 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
I know there are probably enough threads on this to blow my computer, but I had a few specific questions. I've been hard at work getting the AC and tranny cooler in this week and wanted to make more power while I was at it.
A 350 is in best interest however is not feasible right now. So I'm going to do the usually heads and headers (exhaust already done) and possibly a new cam in there. Stuff that will swap to a 350.
Anyway, my questions are, can I Keep the original 700r4 transmission? As well as driveshaft? Im going to get a new gear ratio in the rear. Also, cant the stock fuel pump handle that power or will I need an upgrade along with injectors?
As a side question, does the transmission mount bushing just come out with the bolt? Had a hell of a time getting it out because of the decay on the bolt.
Thanks! Haven't been on here much, been putting some work into it
Old Sep 20, 2015 | 01:22 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Making 300 hp from a 305
Yes same trans will work for both 305 and 350 and will handle 300 HP with no prob. If you want to firm things up alittle you could install a shift kit, .500" boost valve, corvette servo, and a little higher stall torque converter.
With the mild mods you are doing the stock fuel pump and injectors will be fine
The trans mount bolts to the transmission with 2 bolts, then mount has 1 stud that sticks down through crossmember to hold trans to crossmember.
Old Sep 20, 2015 | 09:43 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Awesome! Sounds good then. Do you know who I'd send the computer to for a tune? Best places? There's a place in my hometown but they charge out the a&&I because it's old.
Old Sep 20, 2015 | 01:03 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Is this TPI or TBI? If the latter look up Rbobs EBL Flash. The only thing us TBI guys will use
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Grant2k
Jul 10, 2018 04:01 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
