Help with Fuel pump hoses
Old Sep 23, 2015 | 08:59 PM
shanelique22's Avatar
Car: 1992 camaro rs
Transmission: 5 speed
Hey everyone
I just bought a 1986 Camaro rs. The previous owner hacked up a lot of the fuel system on the car for some reason, but for now I'm starting at the tank and working my way forward. The picture shows the fuel pump hoses( also if you see the poor quality of the tank access hole you should get a good understanding for the quality of work that the previous owner did lol) and he had two of them capped off. I am assuming one is the EVAP the other is the tank vent. You can't see it in the picture but there is a rubber hose that is not attached to anything. Can anybody shed some light on where the two capped lines have to go. Would there be any logical reason to cap these lines on a fuel injected car?
Old Sep 23, 2015 | 10:32 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Help with Fuel pump hoses
One line should goto a line that runs the the evap charcoal canister. The other line should goto a plastic tank vent valve. If both lines are capped, there must be a vented gas cap being used. Tank pressure has to go somewhere.
Old Sep 24, 2015 | 06:30 PM
Car: 1992 camaro rs
I didn't even look at that, I will check it out though. Thanks. Do you work on B-52's?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
