Cam for 305
Old Oct 5, 2015 | 12:26 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Cam for 305
I do have 305 flat tappered 1985 engine and two cams to choose on my table:
1. Summit K1106 http://www.summitracing.com/int/parts/sum-k1106
2. L82 Cam 1979 year
which one should i use, what valve springs to get (or use L82 ones?) for my stock heads (will do some porting), im already have LT1 intake.
Best regards
Old Oct 5, 2015 | 12:50 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Cam for 305
K1106 will be a kind of big cam for a stockish 305. The L82 would be better mannered IMO
Old Oct 5, 2015 | 11:56 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Cam for 305
Wow, do NOT use the K1106 in your 305. It will be a dog and slower than stock.
Way too much duration, and too wide of LSA.
K1103 is the max you would want to go with,
K1102 might even be better
I really do not even recommend the L82 cam. I think it's too big IMHO. Plus it's a very dated old tech profile. It's a 222 @ .050" duration, 114 LSA cam.
So out of your only 2 options, go with the '79 L82 cam
Or look at even a cheap elgin cam/lifter set with 204/214, or 214/224 @.050. They are only like $85, or one of those 2 summit kits for $104
Old Oct 7, 2015 | 12:46 PM
WASyL's Avatar
Re: Cam for 305
Thanks for the input, ill go with L82 then
best regards
alex722607
May 9, 2016 11:00 PM
Lbibb
May 5, 2016 12:00 AM
Iroccer
Exterior Parts for Sale
Oct 10, 2015 04:42 PM
Jawz
Oct 8, 2015 10:58 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
