TPS setting
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
TPS setting
With the no start issue I have, I went and tested the voltage at the TPS. The best adjustment I can get out of my TPS, (end of slots) is 1.8 V at idle and 3.8 V at WOT using my dmm, blk on terminal A and red on terminal B. Does this fall in the range of operational ?
Doing the process of elimination of troubleshooting my no start issue.
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Re: TPS setting
Engine off / key on is the TPS .54 +- .07 ?
I've heard if they are set too high .63 or above it can enable the "anti flood" at cranking (like holding the gas peda) and not run the fuel pump ... I'm new to TPI setups though so Im just spitballing
~DaVe
~DaVe
Engine: 5.7 ltr.
Re: TPS setting
Yes Dave, when the key is in the on position, I get 1.8 volts. The lowest I can adjust it to. I've read on this site the same, but only on the high side of WOT....anything above 6.0 V the ECM goes into "anti flood" mode.
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: TPS setting
Remove the tps from the throttle body and swing the lever through it's full range. Use your DMM to read the voltage as you did before. The tps is a simple potentiometer that has a finite resistance and outputs a voltage in reference to the wiper position in relation to ground and the supply voltage. The ECM provides 5 volts through the tps to ground, this is the range that should be seen at the wiper. The voltage at the wiper is what the ECM uses to determine throttle opening. If you have more than 5 volts at the wiper then the tps is probably bad. Anyway, you should be down around the 0.6 volt range with the throttle closed or the wiper at the ground end of the tps. You need to figure out why it is reading 1.8 volts at closed throttle position. HTH!
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: TPS setting
Engine: 5.7 ltr.
Re: TPS setting
Thanks for everyone's input
gunznrosez87
Oct 14, 2015 11:56 PM
snowflake
Oct 6, 2015 06:47 PM
BrianI
Oct 4, 2015 04:16 PM
